Restoring Serial #18
darwinsowders
Post by darwinsowders »
This is my 1st post on the forum. I started on Snoopy a few months ago but as is typical of me, I'm not making the kind of headway I would like.
I am currently repairing the wings. It was assembled using some sort of brown glue. It has deteriorated to the point that many of the joints just pop apart.
I have some questions that I would like some help with.
Has anyone deleted upper ailerons without enlarging the lower ones? If so, what were the effects?
What wood propeller works well with an O-200? What would be the cruise airspeed? I'm more interested in short takeoff than speed.
Re: Restoring Serial #18
Does it have upper ailerons now? As for the prop, Sensenich can answer that question. Sounds like you want a climb prop. I doubt it would cruise over 85 mph with that configuration.
darwinsowders
Yes, it does have upper ailerons now.
The reason I asked about the prop is that I'm curious about actual results people are getting. That may help me make a better decision when it comes time to order it.
Thank you for the reply. If you have any further thoughts or ideas, please don't hesitate to let me know.
