Someone Looking for Rigging Help
Someone called me about two weeks ago looking for assistance with rigging a CB-1. Unfortunately, your number was deleted from caller id and no phone number was left with the message, so I'm not able to get back to you. If you are reading the forum, please contact me and give me your phone number and I'll try to help you out.
johnkerr
Re: Someone Looking for Rigging Help
Post by johnkerr »
I have developed a step by step guide to the process if anyone is interesed. It is compiled as an blend of information from s number of different sources.
Meadowlark
Post by Meadowlark »
Sure! As someone who sat and looked at the Hatz until it started to make sense how to rig the ship........ I would like to see if I have done it right! This rebuild has been the most frustrating project of my life. After 10 months I finally have the engine hung and more problems have cropped up. I am really anticipating first flight to see how changing the rigging has helped the flight characteristics...... and now winter is coming on.
J/C GTF
wassbiplane
Post by wassbiplane »
johnkerr
I'm gonna rig my KD sometime soon--I'd appreciate a copy too..
Jerry wassbiplane@tds.net
Thanx
John,
I'd like it too. I'll be putting my Hatz back together soon.
biplane1@charter.net
Check the September and December 2003 issues of the newsletter for an article by Bob Whittier on "The Fine Art of Rigging a Biplane"
johnkerr
Post by johnkerr »
Lets see if we can attach the check list.
Rigging Check List-Hatz Classic
SEQUENCE METHOD ADJUST INTEGER
Center Section Plumb line distance to longerons Roll Wires equal
Center Section Incidence Digital Level at each butt rib Rear Cabanes 0 Degrees
Lower Wing Dihedral Digital Level @ Spar Landing wires equal
Lower Wing Incidence Digital Level @ Interplane rib bottom Rear Interplane Strut 0 Degrees
Upper Wing Dihedral Digital Level @ Spar Landing Wires 1.5 Degrees
Upper Wing Incidence Digital Level @ Interplane rib bottom Front Interplane Strut 0 Degrees
Verify all measurements
Tighten all wires to uniform tension (B flat)
johnkerr
Post by johnkerr »
Sorry, The tabulation did not transfer. Create columns for Sequence, Method, Adjust, Integer. Break each line portion under the proper heading.
Re reading this makes the rigging seem less difficult to understand than the checklist.
Rigging CHeck List-Hatz Classic
Sequence Method Adjust Integer
Center Section Plumbline dist. to long. Roll Wires equal
Center Section Incidence Dig Level @ Butt rib Rear Cabanes 0 Degrees
Lower Wing Dihedral Dig level @ Spar Landing wires equal
Lower wing incidence Dig level @ Interplane rib Rear Interplane strut 0 degrees
Upper wing Dihedral dig level @ Spar landing wires 1.5 degrees
Upper wing incidence Dig level @ Interplane rib Front interplane strut 0 degrees
Contact me direct for a excel spread sheet.
