Motor mount, nose bowl, carb heat/air intake box for 0-320 f
Replacing my 0-320 with a radial motor. Don’t need my nose bowl, dynafocal motor mount (0-320), and carb intake box with filter (C172) modified to fit Hatz with pressure cowl. Nose bowl is in excellent shape with blind nuts installed. Dynafocal mount was professionally built by Weldtech Aero and has about 400 hrs. of use. Carb intake box was assembled using the good parts of two unuseable C172 intake carb boxes. Bushings are tight and in good shape. Asking $75 for nose bowl, $275 for engine mount, $100 for carb heat box. All for $375. Call Mark at five one three 907five five 71. Pics on request.
LarryC
Re: Motor mount, nose bowl, carb heat/air intake box for 0-320 f
Post by LarryC »
Interested in the nose bowl. Do you have the rest of the cowling to go with it? Can you send pictures to this email. lmc2wings@yahoo.com.
Thank you
Larry C.
tacobfamily
Post by tacobfamily »
I may in the near future be replacing my old 0290 for an 0320. I was wondering if you still had your engine mount and other part available?
You can contact me at +13862924737
Or email me at tacobfamily@yahoo.com
Thank you Scott Bell
