ISO:Engine and propeller combinations
Posted: Thu Sep 10, 2020 7:02 pm
    I’m using an O-320 with a wood 74x54 prop. Im interested in what other Hatzers with O-320s are using for props and what amount of engine offset they used when building. I’m running out of options to remedy a fairly strong left turning tendency. e.g. when I bank to the left all is well rolling back to the right much more stick force required. Maybe that’s normal. All wing rigging double checked and tail checked as well. Vertical fin offset 1” for the 150 hp. I will be going back and checking my engine offset next. Looking for other things I can check.
    Re: ISO:Engine and propeller combinations
    Posted: Mon Sep 14, 2020 11:17 am
    by hatz215
    Do you have a trim tab on the rudder?
    Posted: Wed Sep 16, 2020 9:44 am
    No Steve I don’t have a rudder trim tab. My goal is to try everything I can think of and then add a trim tab if needed. It’s looking like I may need one. Could you share your experience on the best way to approach adding a tab on the rudder.
    Thanks for the reply and sorry for the delay.
    Posted: Wed Sep 16, 2020 11:47 am
    by hatz215
    I just attached to the bow with 2 sheet metal screws. My tab is probably around 4 " tall
    Posted: Wed Sep 16, 2020 8:21 pm
    I see. 4” x ?”
    Posted: Thu Sep 17, 2020 3:48 pm
    by hatz215
    It probably has about 2" aft of the bow
    Posted: Fri Sep 18, 2020 6:05 am
    Thank you!
