Rotec Ignition
Posted: Thu Aug 06, 2020 6:05 pm
A couple of questions. I can't find a forum on the Rotec engine. Is there one?
I'm working on the firewall. A mechanic (auto) was looking it over and mentioned that the ignition module may be affected by the coil and I should keep them apart. I didn't see any specific instructions in the Rotec operations manual other than the ignition coil should be mounted with the high-tension post vertical. The wire harness is 26" between the module and the coil and 29" between the module and the hall sensor in the distributor. I'm not sure if this is for convenience to place the components anywhere practical or to keep them apart?
