HC #86 Update
Posted: Fri May 24, 2013 2:07 pm
by splischke
I just finished cutting the finishing the floor boards. It was a bit tedious work but I enjoyed it. The EV-400 Epoxy varnish really shines!
Re: HC #86 Update
Posted: Fri May 24, 2013 2:40 pm
by PoconoJohn
I enjoy the photos on your website; they help a lot. Looking good there Scott.
Re: HC #86 Update
Posted: Sat May 25, 2013 2:20 pm
Here is a suggestion that worth adding on the Classic with the stepped floor boards.
Re: HC #86 Update
Posted: Sat May 25, 2013 2:43 pm
by splischke
Great idea and easy to implement. Thanks!
Re: HC #86 Update
Posted: Mon Aug 24, 2015 11:39 am
Can anyone explain the reason that the floor is higher in the rear of the Classic. To me the step seems to create a problem with the ruder pedals. I like the ramp suggestion but why not just make both floors the same elevation. Is there any interference that I am not seeing?
Re: HC #86 Update
Posted: Mon Aug 24, 2015 7:15 pm
The raised floor provides clearance for the aileron push tubes which run under the floor.
