I'm back, and have a question
Posted: Wed Oct 17, 2012 7:31 pm
Hello all!
It's been quite a while since my last post, not since the old forum, actually. I've been slowly making progress on my Classic, and hope to set up a website soon to post pictures and log my progress. I have been following others' postings and progress, and appreciate all that I have learned from them. Hopefully I can contribute something now.
I am finally finishing up the last of the steel parts and fittings for my wings. Once all of these are primed, all of the "little parts" for the wings will be done. I'll finally then be ready to start planing and drilling my spars and thereafter actually assemble the wing panels.
One part has me stumped, though. Looking through the photo CD that Jeff Shoemake supplies with the plans, I noticed a brace for the bottom wing #2 compression tube that does NOT appear on the plans. Its purpose I would presume is to brace the compression tube to relieve bending loads that would be imposed by the aileron idler.
Question one: Is this part really necessary? I can't quite tell if this is just something a builder added on his/her own, but since it's on Jeff's CD, I would think that this was added later, and perhaps the plans were subsequently changed. If you are a builder of a plane on that picture CD, could you please enlighten me? What has everyone else done?
Question two: If this brace is necessary, what size tubing was used? Wall thickness? It probably attaches to the compression tube using the same AN-4 bolt as the aileron idler, but what bolt should be used on the spar?
Thanks!!!
Thanks!!!
