Center section discrepancy
I don't see this in the discrepancy section, so maybe I'm wrong....but looking at the center section sheet 3 on the left side, it appears the nose ribs have a notch to sit on the base of the center section. My nose rib drawing does not have a notch (the tail pieces do).
Re: Center section discrepancy
You are correct, I had to create the notch.
